Dealer says Honda changed oil recommendations
Old Jan 29, 2015 | 12:50 PM
Carta's Avatar
Default Dealer says Honda changed oil recommendations
My son's 2010 Accord EX was brought in to the dealer for an oil change. The oil fill cap has imprinted on it 5W-20 but the service writer said Honda changed their recommendations to 0W-20 synthetic (full or blend). I went ahead with this; they charged $58 for the oil change.
Is this accurate--Honda recommends 0W-20 and for an older model, the 2010? Up until today, the car has had 5W-20 conventional/organic oil at every change.
Old Jan 29, 2015 | 12:57 PM
For a 2010 Accord, the recommended oil is 5W-20; but, 0W-20 is acceptable.
For 2011 to current Accords, the recommended oil is 0W-20.
Old Jan 29, 2015 | 01:22 PM
Insist on 5W-20 if that is what you prefer and also to save some money for the 2010 Accord.
Honda usually publishes engine oil applications guides annually. The service writer may have been mistaken.
I don't recall them all at this moment; but, there were a few powertrain changes to the 2011 Accord vs. 2010 Accord.
Old Jan 29, 2015 | 01:38 PM
shipo's Avatar
FWIW, 0W-20, while it may cost a bit more, is superior to 5W-20 in every way. Personally I would insist on 0W-20.
Old Jan 29, 2015 | 01:47 PM
Carta's Avatar
I don't have a preference and while the synthetic blend is expensive, I'm okay if it benefits the car.
Shipo--what do you see as superior about using 0W-20 over 5W-20?
BTW: I live in northern Alabama where it's hot in the summer but in the winter, once in awhile overnight temps. fall to low teens. Not sure if that makes a difference.
Old Jan 29, 2015 | 03:03 PM
shipo's Avatar
Oil in the 0W-20 grade is a full synthetic (at least I've yet to see a lesser oil in that grade), which by definition means it will exceed the performance of a 5W-20 semi-synthetic due to the superior quality of the base stocks for the oil and the need for significanly fewer additives (which in turn means the oil has a greater capacity to safely carry contaminates).
Base stocks aside, 0W-20 will pump up to the top end of your engine quicker following a cold start, even if said "cold start" is in the middle of an Alabama summer.
Old Jan 29, 2015 | 03:17 PM
5W-20 is available in full synthetic, semi-synthetic, or conventional.
Old Jan 29, 2015 | 03:44 PM
Carta's Avatar
Okay, well, I appreciate the answers and I now know more about the differences in oil. Just one more question: if you use full or partial synthetic ("blend" as my dealer calls it), do you do any harm if you get an oil change with conventional / organic oil on occasion? I ask because I had a blend in a 1999 Accord and then forgot about it when I went to a quickie oil change place. Thanks again!
Old Jan 29, 2015 | 05:57 PM
Should be no harm.
Old Jan 29, 2015 | 06:28 PM
shipo's Avatar
No issue what-so-ever. That said, I don't believe there is such a thing as a true conventional/organic oil in the 5W-20 weight. As I understand it, the "conventional" 5W-20 specification requires a fairly significant percentage of the base stock to be at least a Group III synthetic. Said another way, in the 5W-20 grade, your two choices are Semi-Synthetic or Full-Synthetic.
