Desperate, please help
Old Apr 9, 2012 | 06:37 PM
americanguy's Avatar
Default Desperate, please help
I have a 1998 accord. the idle on it is not good. sometimes it idles back and forth from 1100 to 2100 rpms. i changed the iacv, and the map sensor. there is a lot of suction where the idle air control valve is, in the hole there. should this be, PLEASE HELP? its a 1998 so it doesnt have a fitv valve does it? coolants good, wat else shall i check
Old Apr 9, 2012 | 06:47 PM
jroxz44's Avatar
Almost A Senior Member
Any CEL on? Sounds like maby a sensor. Or vaccume leak. And what hole are u talking about?
Old Apr 9, 2012 | 06:54 PM
If you have replaced those I would look for a vacuum leak. Check the throttle body, intake manifold, and all the sensors from the intake manifold to the head.
Old Apr 9, 2012 | 06:55 PM
its the hole there in the front valve if that tells u anything, what for sensor wud it be?
Old Apr 9, 2012 | 06:56 PM
hey thanks a lot live2rice, does it have a fit valve?
Old Apr 9, 2012 | 07:32 PM
jroxz44's Avatar
Get a vaccume gauge with a T fitting and start checkin vaccume hoses and compair with shop manual. I wrapped all my vaccume hoses in electrical tape where they connect to metal hoses because i had provlem with mine blowing off and leaking all the time. Even slight leaks cause problems. But id check them first cause it sucks cutting tape everytime u gotta replace something.
Old Apr 10, 2012 | 08:16 PM
hey, jroxz44, u had asked wat cel was on. the iacv sensor was on and the map sensor was on. i changed that,now its telling me the iat sensor is bad, which ithadent earlier. shud ichange this sensor? thanks
Old Apr 10, 2012 | 09:53 PM
crispin's Avatar
Have you bled the air out of the coolant system?.
Idle going up and down is a symptom of air in the system.
Old Apr 11, 2012 | 10:03 PM
yes, i bled the system that doesnt work, i looked today on top of the air manifold there r three differnet places for hoses, two which have hoses to them, i which doesnt. this is sucking air in, shudnt there be a hose connected there???
Old Apr 12, 2012 | 07:37 AM
crispin's Avatar
yes
this should help
