Detaching Vacuum Line on Fuel Rail
Old Jul 17, 2014 | 09:41 AM
cukaracha's Avatar
Default Detaching Vacuum Line on Fuel Rail
Hello,
I'm trying to clean out the EGR ports on my '94 Accord LX. I've watched a couple of videos and also read the tutorial in the DIY section. However, I can't seem to detach the vacuum line on the fuel rail? The rubber hose seems stuck on both ends. To illustrate, please watch 1:40 on this video:
Any advice?
Thanks!!
Old Jul 17, 2014 | 02:40 PM
Only vacuum line to fuel rail is vacuum reference line to the fuel pressure regulator.
Video refers to vacuum line to the EGR valve.
In both cases, vacuum lines can become stuck due to heat/age. It is sometimes necessary to twist carefully w/ pliers to break the rubber/steel bond and enable removal of vacuum tube.
Old Jul 17, 2014 | 02:47 PM
cukaracha's Avatar
Thanks for the reply! Seeing how the rubber hose is probably brittle at this point, should I take any extra precautions when putting it back on? Perhaps some kind of sealant?
Old Jul 17, 2014 | 03:25 PM
Honda vacuum lines are very good quality. I've seen 20 yr lines that were flexible and serviceable. If end is cracked/split or permanently swelled, cut the end off (perhaps 1/2" no more) and you should be fine.
Old Jul 17, 2014 | 04:05 PM
cukaracha's Avatar
Worked it off gently with a pair of pliers like you suggested and it came right off. Also seems to be in good shape and had a good seal when I put it back on as is.
Thanks so much for the help!!
BigOBob
Jan 1, 2012 02:47 PM
live2rice
Jul 15, 2011 02:38 PM
fortyfootelf
Jan 22, 2010 07:15 PM
ohanahorse
Sep 15, 2009 10:38 AM
tru3_k177
Jan 10, 2009 03:25 AM
