Details on how to replace slave cylinder
Old Nov 11, 2010 | 08:56 PM
91exluv's Avatar
Default Details on how to replace slave cylinder
Year and trim accord : 1991 ex 4 door (dual exhaust) Honda Accord
Your request for a DIY write up : How to replace slave cylinder
Any additional notes that need to be added : the slave cylinder is mounted to the front of the transmission, right by the fan, real tight space to get into, just need a little direction on the best approach. Thanks
Old Nov 12, 2010 | 09:27 PM
You might want to remove the fan & give yourself more room.
It's basically un-bolt it & bolt on the new one. Sounds easy, huh? Corrosion will get you (especially the hydraulic lines - flare fittings). Use lots of PB Blaster & let it soak in overnight.
Old Nov 13, 2010 | 06:52 PM
91exluv's Avatar
Thanks so much!
Old Nov 13, 2010 | 09:12 PM
OH yeah, for the hydraulic lines, get a flare-nut wrench. It's like a box-wrench but it's got a cut-out so you can put it over the tube. That works much better than a normal open-end wrench.
Old Nov 14, 2010 | 03:35 PM
91exluv's Avatar
yeah, I had to get one of those when I first started on this, I realized that my normal wrenches wouldn't work too well. Thanks!!
PAhonda
Jul 25, 2008 12:40 PM
Buktheng
Feb 11, 2008 06:31 PM
otherhonda
Dec 7, 2006 08:16 PM
gonecrazy
Oct 12, 2005 11:57 PM
gonecrazy
