Distributor/ignition problems
Old Sep 26, 2007 | 09:23 PM
sashka
Default Distributor/ignition problems
I need help!!!
I have a 1992 accord 4 door lx and i had a leaking distributor and so i bought a used one but the used one had a coil inside the distributor and all i needed was the shaft because the bearing on the original was done. So all i took off the new distributor was the main aluminum distributor part, the shaft, the coupling and the orings and little washers and stuff.The ICM, CKP/TDC/CYP sensor, rotor, wiring, and capare all from the original distributor. I get that all together and put the distributor backin andhook everything back upbut the car does not want to start, it doesnt backfire, justturns overwithout starting. Would anybody know what i might have tocheck? maybe ignition timing??? if so, whats the best way to do it? or something else??
Alex
Old Sep 26, 2007 | 11:06 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Distributor/ignition problems
Did you install the new dist 180 degrees off?
Old Sep 26, 2007 | 11:28 PM
sashka
thats exactly what the problem occurs in..
thanks bud
Donpop
Mar 3, 2013 03:49 PM
shehadehd
Sep 20, 2012 05:20 PM
jmcmichael08
Oct 19, 2009 12:55 PM
mepenzien
Jul 20, 2007 03:13 PM
KimberlyC
Apr 16, 2006 11:51 AM
