Distributor leak 5th gen
Old Feb 23, 2011 | 02:05 PM
Hydronnner's Avatar
Default Distributor leak 5th gen
I have a 95 accord lx wit a f22b (vtec) engine installed on it. Since the distributor cap was broken i got another cap and it worked just fine but i soon started to notice small oil spills on the ground and now its all over my 5 speed tranny. I was just wondering if this method in the link will it fix my problem?
honda-tech.com/showthread.php?t=2214402
It leaks from that bottom ^^ point on the distributor.
Old Feb 23, 2011 | 02:35 PM
If you remove the distributor cap, is there oil inside of the distributor?
Old Feb 23, 2011 | 04:45 PM
Hydronnner's Avatar
yes it is just along the bottom. It is not filling the cap up because the little rubber seal i received for my distributor cap was different shape than my cap, so it extends beyond my cap and is not sealing it so oil just flows out freely. But it does look like its coming from internally.
Old Feb 23, 2011 | 05:25 PM
I would replace the internal seal. I would also replace the o-ring shown in the last pic of the DIY.
There are some steps that are left out of that DIY. Before you remove the distributor, mark a line across where the distributor/cylinder head meet. It is where the top bolt holds the distributor housing. You want to do this because the distributor can rotate to adjust timing. Yours is already adjusted, so why add more steps at the end? You will align the two marks when you reinstall and your timing will be set.
Also, here are some pointers on that DIY. Notice which screws remain in the very first picture at ~10/11 o'clock, so you don't remove them on your distributor.
On the second picture, see how the key has a line going through it? That key is offset, so you can't install the whole distributor 180 degrees off. Before removing the key, mark the distributor shaft where the rotor bolts, so you know which side of the rotor shaft the line in the key faces. If not, then the distributor will be 180 off and your car won't start.
Old Feb 23, 2011 | 05:45 PM
Hydronnner's Avatar
So these
autopartswarehouse.com/sku/Honda/Accord/NOK/Distributor_Seal/1996/EX/4_Cyl_2-dot-2L/W0133-1640599.html?tlc=Engine+%26+Drivetrain&intcmpid=Pr oduct+Listings+Best+Seller#reviews
And
autopartswarehouse.com/sku/Honda/Accord/Ishino/Distributor_O-Ring/1996/EX/4_Cyl_2-dot-2L/W0133-1644035.html?tlc=Engine+%26+Drivetrain&intcmpid=Pr oduct+Listings+Best+Seller
Those should be fine for the seals?
Old Feb 23, 2011 | 07:02 PM
Yes. I removed the active link on your posts. It is one of the forum rules.
If you are going to put up links remove the http:// and the www. part of the link.
Old Feb 23, 2011 | 07:15 PM
Hydronnner's Avatar
aw yup. Sorry bout that, ill do it like that next time. So ill order these and try them out and get back with you when i try them out. Thanks for the verification
Elk Hunter
Oct 2, 2012 11:08 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
finch13
Apr 15, 2008 10:13 AM
New5thGenAccordTuner
Jan 22, 2006 03:43 AM
