Distributor Rotor Differences
Old Apr 19, 2014 | 05:56 PM
RobinsonRicer's Avatar
Default Distributor Rotor Differences
I'm looking into another tune up but I remember last time I replaced my distributor rotor the product that showed up for the f22b1 (vtec) didn't fit on the distributor. Turned out the f22b2 (non-vtec) fit. But I have the vtec engine.
I can't remember the exact part but I'm wondering if some of the vtecs have different rotors? I'm pretty sure this is a hitachi.
Thanks
Old Apr 19, 2014 | 07:31 PM
In regards to the distributor rotor, there is a difference between the EX (vtec) vs LX and DX (non-VTEC).
The rotor for an EX is the same for model years 94-97 on a 4 cylinder engine. The rotor for LX and DX are the same for model years 94-97.
If you talk about the distributor housing, then there is a difference in model years 94-95 vs 96-97 for the 4 cylinder.
Old Apr 19, 2014 | 08:18 PM
Its the rotor oddly enough. The non vtec fit but the vtec did not fit. The engine runs fine and the distributor is a hitachi. Maybe it was the difference in years and just a coincidence.
So whats the difference in the early and late model rotors then? Function wise the same or is it because of the obd1 and 2 differences?
Old Apr 19, 2014 | 08:37 PM
94-97 EX with Hitachi Distributor: Rotor 30103-P0A-A01
94-97 LX, DX with TEC Distributor: Rotor 30103-P08-003
Old Apr 20, 2014 | 08:33 AM
Distributor housing is different between the obd1 and 2 5th gens and also the vtec and non vtec? I do know that the non-vtec has the ignition coil outside the housing.
I guess the database at advance auto mightve been incorrect. Thanks for the part numbers.
Old Apr 20, 2014 | 10:06 AM
The following are some of the differences:
94-95 EX and Canada EX-R
  • TDC/CKP/CYP sensors are inside distributor housing
  • 8P and 2P gray wire connectors
  • internal ignition coil
94-95 DX, LX and Canada EX
  • external ignition coil
96-97 EX
  • CYLINDER POSITION (CYP) SENSOR inside distributor housing
  • 5P and 2P gray wire connectors
96-97 DX, LX, and SE and Canada EX
  • 4P and 2P gray wire connectors
CRANKSHAFT POSITION/TOP DEAD CENTER (CKP/TDC) SENSOR is not inside the distributor for 96-97 DX, LX, SE, EX and Canada EX. The combined CKP/TDC sensor is located behind the crank pulley.
gearshift
Nov 11, 2008 09:24 PM
ranma21
Oct 21, 2008 12:23 AM
ranma21
Oct 21, 2008 12:21 AM
dacecil
Jan 27, 2008 05:29 AM
Dazed
Jul 28, 2007 11:37 PM
