door panel removal, handle and lock is holding it in
Old Jun 22, 2005 | 06:09 PM
ryan ortego
Default door panel removal, handle and lock is holding it in
Hello,
i need help gettin my door panel off. 1990 honda accord 4 door. I have all screws off. The bottom half is off. The only thing holding the door on is the handle and lock piece. I have the one screw off, there is something inside the door that is holding it on. What is it and how do i get it off. Thanks so much
Ryan
Old Jun 24, 2005 | 08:31 PM
Shocker's Avatar
Default RE: door panel removal, handle and lock is holding it in
on the door handle there a clip kinda thing that attaches to the aluminum piece that opens ur door... u need to unclip that to take the handle off....
is it manual or auto?
Old Dec 4, 2005 | 02:24 PM
overlordjd's Avatar
First of all, if you haven't done this. You need to push the entire lock unit forward to unclip from the door. Once thats accomplished there is a plastic clip that connects the rod that operates the door lock to the handle. you need to unclip that but be carefull not to break it. Thas sometimes happen when they get old. Good luck
Old Dec 4, 2005 | 04:10 PM
beets442
overlord is right , the clip will break if your not carefull-alittle light oil an a small screw driver ,lightly push clip off off rod
moparmusclecars
Jul 16, 2013 10:10 PM
Doublel
Mar 11, 2013 07:57 AM
nismogrendel
Feb 7, 2013 07:03 PM
JPodAccord
May 26, 2012 05:10 PM
Motman Idaho
Mar 22, 2012 10:20 PM
