door won't open on 2000 accord
My driveside door won't open from inside or out. I already have the door panel off and I have tugged on all the linking rods. Nothing happens. Is there anything else to try or does the latch need to be replaced? If I do need to repalced the latch, how can I open the door to remove the latch screws, or can the latch be busted out from inside? thanks in advance for your help.
RE: door won't open on 2000 accord
Hi Member, take off the door panel on the working side and see what's missing or not in place then go from there..
WheeLBrokerAng [sm=americanasmiley.gif] |
Thanks for the answer. IU already got panel off and nothing looks out of order. I think the latch is broken. Assuming this to be the case, what now.
There was a procedure for earlier models to drill out the door latch. I think there was a TSB on this procedure. It requires precisely drillinga hole in the latch assembly to allow a tool to release the latch. I don't have access to TSB's to search. You might try googling for the procedure.
good luck |
WHats your year / model?
2000 ex sedan v-6 with automatic locks.
Found the following w/ a good pic that may be some help.
http://autorepair.about.com/library/a/1i/bl203i.htm good luck |
