door won't open on 2000 accord
Old Jun 9, 2007 | 07:25 PM
robstuff's Avatar
Default door won't open on 2000 accord
My driveside door won't open from inside or out. I already have the door panel off and I have tugged on all the linking rods. Nothing happens. Is there anything else to try or does the latch need to be replaced? If I do need to repalced the latch, how can I open the door to remove the latch screws, or can the latch be busted out from inside? thanks in advance for your help.
Old Jun 9, 2007 | 08:13 PM
Default RE: door won't open on 2000 accord
Hi Member, take off the door panel on the working side and see what's missing or not in place then go from there..
WheeLBrokerAng [sm=americanasmiley.gif]
Old Jun 9, 2007 | 08:22 PM
robstuff's Avatar
Thanks for the answer. IU already got panel off and nothing looks out of order. I think the latch is broken. Assuming this to be the case, what now.
Old Jun 9, 2007 | 08:40 PM
There was a procedure for earlier models to drill out the door latch. I think there was a TSB on this procedure. It requires precisely drillinga hole in the latch assembly to allow a tool to release the latch. I don't have access to TSB's to search. You might try googling for the procedure.
Old Jun 9, 2007 | 10:03 PM
smaglik's Avatar
WHats your year / model?
Old Jun 10, 2007 | 06:44 AM
robstuff's Avatar
2000 ex sedan v-6 with automatic locks.
Old Jun 10, 2007 | 07:44 AM
Found the following w/ a good pic that may be some help.
http://autorepair.about.com/library/a/1i/bl203i.htm
Kelsen
DIY Answers.
Apr 7, 2020 11:46 PM
jerzeegirl70
Jul 22, 2012 11:44 AM
spinner
Apr 6, 2007 02:08 PM
jellero
Oct 11, 2006 06:10 PM
