2003 Accord coupe passenger door won't open from inside or out
Old Jul 22, 2012 | 01:17 AM
jerzeegirl70's Avatar
Default 2003 Accord coupe passenger door won't open from inside or out
I have a 2003 honda 2 door and the passenger door does not open from the inside or out passengers have to crawl in from the drivers side. Very frustrating. How can I get passenger side door open to get door off to see what the problem is
Old Jul 22, 2012 | 11:44 AM
It may be a problem with the door latch.
When you pull the door lock **** up, how does it feel? Do you hear anything when you do this?
Use the remote to unlock, then try to open the door with the outside handle and inner handle.
If it still doesn't open, you may have to attempt to remove the door panel and try different things, such as pulling the inner handle cable; pulling the outer handle rod, etc.
This link shows how to remove the door panel on your car. Follow Step 1 (steps 1A - 1h). It may be difficult to pull the panel with the door closed; but, you may be able to do it.
http://www.dormanproducts.com/Digita...741-306_IS.pdf
Attached Thumbnails 2003 Accord coupe passenger door won't open from inside or out-2003-2007-actuator-latch.jpg
reddem0n
Aug 17, 2014 11:01 PM
jaredfire
Jul 4, 2014 10:02 AM
Malcontent
Apr 12, 2014 01:37 PM
bds85466
Jan 19, 2014 05:19 AM
baitshopboy
May 23, 2012 07:08 PM
