1995 Accord Drivers door won't open from Inside
Old Apr 12, 2014 | 12:49 PM
Malcontent's Avatar
Default 1995 Accord Drivers door won't open from Inside
I was trying to open the door from inside and heard a loud "ping" like a metal spring or pin broke and it did not open.
It opens fine from outside but inside handle feels not connected to anything.
I haven't taken anything apart yet, any advice before I do?
Old Apr 12, 2014 | 01:37 PM
Go to youtube and look at videos of door panel removal. Also go to DiY forum, Online Manuals post and download the 94-97 Accord manual. It has diagrams and procedures. Pay particular attention to how to remove the inner door handle; remove screw, slide handle assy forward, and release clip to door handle actuator rod. Here is one example:
I would suspect that inside door handle mechanism has failed. I had this happen on 90 Accord. It was a plastic part failure.
After removing inner door handle assy, check whether you can open door by pulling on actuator rod. If problem is w/ connection of rod to door latch mechanism, you may have a more difficult problem to repair.
reddem0n
Aug 17, 2014 11:01 PM
bds85466
Jan 19, 2014 05:19 AM
Haulin' Honda
Dec 25, 2012 12:51 PM
jerzeegirl70
Jul 22, 2012 11:44 AM
lakehopper
Aug 15, 2007 11:28 PM
