Driver Door Power Lock does not Work
Old Mar 27, 2011 | 07:48 PM
accordgary07's Avatar
Default Driver Door Power Lock does not Work
The driver door lock is working independantly from the other door locks and will not function from the Remote. Passenger and rear doors function when the remote is pushed but the driver door requires the key for entry and manually looking. Any ideas?
A year ago the entire master door switch was replace when the locks were not functioning properly and that solved the problem. Could this be the same switch again or an actuator in the driver door, or something else. Has anyone had this problem?
Old Apr 2, 2011 | 08:40 PM
bdschmidt07's Avatar
I have the same problem. Have you discovered a fix?
Old Apr 10, 2011 | 07:47 AM
No, I have tried the standard reset procedure, did not work.
Rob2000AccordLX
May 9, 2014 06:23 PM
jza240sx
Apr 30, 2013 04:14 PM
x13darkmatter
Mar 3, 2013 02:52 PM
mjquillici
Mar 21, 2011 10:59 PM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
