Driver side A/C hot, passenger side cold ??
Old Sep 18, 2012 | 11:36 AM
ryanw2427's Avatar
Default Driver side A/C hot, passenger side cold ??
Air on the driver side is blowing out hot, and on the passenger side blowing out cold. Does anyone know what could cause this?
ETA: It's a 2007
Old Sep 18, 2012 | 11:42 AM
Usually due to low refrigerant.
There's a few similar threads on this forum.
Old Sep 18, 2012 | 11:58 AM
Dr. Drivability's Avatar
i'll have to take objection to that redbull, may be a blend door related problem. need to pull codes out of the climate control unit and report back.
Old Sep 18, 2012 | 12:04 PM
I respect your comment.
Old Sep 18, 2012 | 12:16 PM
Here is a thread regarding only the passenger side being cold due to low refrigerant:
https://www.hondaaccordforum.com/for...er-side-47530/
However, like Dr. D. stated, can be a blend door problem. My guess would be low refrigerant.
Old Sep 18, 2012 | 02:43 PM
What's the over under on that one????
Old Sep 19, 2012 | 08:39 PM
ryanw2427's Avatar
Ok this is strange. Took it to the mechanic and he started turning the passenger climate control **** all the way down to "Lo"... after which the DRIVER side air got down to the correct temperature when it was also turned down to Lo. Now taken off of dual mode, it's blowing out the same temp on both sides
Also... it's interesting to note that the passenger side **** doesn't stop turning... ever, while the driver side stops turning when it reaches "Lo." Not sure if this has anything to do with it
tr0910
Jun 7, 2015 03:04 PM
Sapowell84
Jul 16, 2013 03:18 PM
jza240sx
Apr 30, 2013 04:14 PM
sbi
May 19, 2012 08:38 PM
19accord92
Apr 10, 2006 03:52 PM
