Driver side leaking water?
Hi
Before I posted a problem with the revolutions and was the Idel control was dirty. Thanks a lot for the help. Now I have new problem coming out from my front diver side. I saw that my carpet was kind of wet so I decide to remove it and when I took it of there was a puddle. The water was clear and I guess this is happening when I turn off my air condition. I will appreaciate any help once again. oh its a Honda Accord 98 Ex Many Thanks |
RE: Driver side leaking water?
The ac evaporator and evaporator condensate drain are on the passenger side. Hard to see how condensate could reach the driver's side. I would suspect either you left a window partially open and rain got in, perhaps driver's door seal leaking, power windowguide channels damaged or missing, or you have a windshield leak.
Clear water thankfully rules out a leaking heater core. good luck |
windshield work done recently ?? could be form the moon roof
Greetings guys sorry for the delay answer I been working in the car and I found a plastic pipe in the driver side left panelupper and that pipeis the one that is causing the puddle in my side but I don't know of what is that plastic like clear pipe. Butnow I got a bigger trouble how I can open my car by mistake I left the only key inside of it. Im been passing troubles and situationsthat you couldn't imagen. I will apreaciate any help once again guys.
Many thanks |
The plastic tube might be a sunroof drain tube?
The '98 Accord has pretty stout window frames. If you wanna break in you'll probably do enough damage to the window frame & door opening; so I bet a locksmith would be the best way. |
my carpet at least is removed I just took off the black cap that drains the water and I luckly opened the hood. what can I do from there? Im just trying to reach the trunk so I can open it.
Many Thanks. |
I finally opened my carcuting a small piece with the wrench . I used a large stick to pick the keys and drop them to the bottom. I fix the leak by connecting the pipes and now it shouldn't be no leak.
Thanks a lot |
| All times are GMT -5. The time now is 03:47 AM. |
