Drivers side headlight bulb 97 accord V6
PLEASE read the posting rules.
I've moved this to General Tech as questions like this do not go in the DIY Section.
Removed lock ring - counter clockwise.....can be stuck and hard to do but lube and that might help.
Wiggle (yes technical term) and pull at the same time on the base of the bulb.
Remove wires.
Install in reverse....please do your best not to touch the glass part of the new bulb with your hands.
Remove wires.
I know how to remove & replace the bulb, done some on my '95, but the '97 I now have has no clearance for my hand without removing the battery and whatever that other thing is! I want to know how to remove it!
I just replaced drivers side low beam on my '97 Accord V6 and had to remove the battery, the coolant overflow tank, a shroud in the corner that connects to the air intake then the bulb...not too bad, but could be a lot easier...Honda...go figure!
Creepyjeeper
May 26, 2012 04:48 PM
sskkf
Jan 19, 2007 04:23 PM
