Drivers side headlight bulb 97 accord V6
Old Apr 18, 2013 | 10:41 PM
"974thAccord"'s Avatar
Default Drivers side headlight bulb 97 accord V6
Old Apr 19, 2013 | 05:31 PM
PLEASE read the posting rules.
I've moved this to General Tech as questions like this do not go in the DIY Section.
Removed lock ring - counter clockwise.....can be stuck and hard to do but lube and that might help.
Wiggle (yes technical term) and pull at the same time on the base of the bulb.
Remove wires.
Install in reverse....please do your best not to touch the glass part of the new bulb with your hands.
Old Apr 20, 2013 | 08:56 AM
thanks, I was wondering about the item between the battery and the headlight, it looks like a coolant recovery tank. I also see the battery must come out too.
Old Apr 20, 2013 | 08:59 AM
I know how to remove & replace the bulb, done some on my '95, but the '97 I now have has no clearance for my hand without removing the battery and whatever that other thing is! I want to know how to remove it!
Old Apr 20, 2013 | 11:33 AM
I believe what you are talking is a "vent tube" for the battery.....just gently grab and pull straight up.
Got a picture of the area.
Old Apr 20, 2013 | 12:11 PM
Sorry, on the 6cyl it looks like there is a bolt (#15 in pic) that holds that tube down.
Attached Thumbnails Drivers side headlight bulb 97 accord V6-5th-gen-v6-air-res.jpg
Old Apr 21, 2013 | 01:30 PM
I just replaced drivers side low beam on my '97 Accord V6 and had to remove the battery, the coolant overflow tank, a shroud in the corner that connects to the air intake then the bulb...not too bad, but could be a lot easier...Honda...go figure!
Creepyjeeper
May 26, 2012 04:48 PM
kouken
Jan 24, 2012 01:41 PM
duanehj
Aug 3, 2010 02:49 PM
indy49
Jan 30, 2007 01:18 PM
sskkf
Jan 19, 2007 04:23 PM
