Driver's side heater stuck on.
Old May 9, 2012 | 09:02 AM
zoid_99's Avatar
Default Driver's side heater stuck on.
Hello everyone. My 2003 EX has had a rough 6 months. The lastes is that the heater on the driver's side is stuck on. In other words I turn the thermostat all the way down on both sides and the drivers side blows hot (really hot) and the passenger side blows cold (really cold). I'm guessing a flap stuck open somewhere? I search around and didn't find anyone with this exact issue.
Thanks!
Old May 9, 2012 | 09:30 AM
zoid_99's Avatar
Default I think this fixed it...
I found this doing a google search:
HOW TO RETRIEVE A DTC (WITHOUT HDS)
The audio-HVAC display panel has a self-diagnosis function for climate control. To run the self- diagnosis function, do the following:
1. Turn the ignition switch ON (II).
2. Set the driver's temperature control dial or button on MAX Cool.
3. Press and hold the OFF button.
4. While holding the OFF button, press the rear window defogger button five times within 10 seconds.
The self-diagnosis will begin.
After I did that it ran through the diagnosis and now it appears to be functioning normally. Hopefully it just needed a reset of some sort.
Old May 9, 2012 | 06:48 PM
Good job.....in the "Common DIY Threads" sticky at the top of this section is the same information, it also has how the read the codes if you have any
Old May 9, 2012 | 07:14 PM
If it comes back, I would suspect a problem with the driver's side mode mix motor. Easy replacement. But, the trouble code would help narrow it down if the problem comes back.
Old May 17, 2012 | 08:32 AM
zoid_99's Avatar
Well it happened again. I ran the self-diagnosis and it fixed it again but I'm not seeing any codes. Once the self-diagnosis is done all of the display elements just blink over and over. Where should I see the codes?
Thanks to everyone on this forum! This is a great resource.
Old May 17, 2012 | 06:03 PM
Read my second post in the DIY.
jza240sx
Apr 30, 2013 04:14 PM
kodoo
Feb 3, 2012 06:54 PM
ndp
Jun 7, 2009 05:23 PM
19accord92
Apr 10, 2006 03:52 PM
