DRL
Old Sep 14, 2007 | 08:04 AM
surajsss
Default DRL
Hello,
I have a 2000 Accord SE. I want to make it compliant to Canadian standards. Do you know where can I get DRL modules and how easy it is to fix ?
TIA.
Old Sep 14, 2007 | 08:37 AM
falkore24's Avatar
Default RE: DRL
On mine, if I leave the lights on, they will turn off after a few minutes when I turn off the car. If you have this, then you can leave the headlights on all of the time with no modification. Otherwise you can make the modules yourself as all is needed are a couple of relays and fuse holders. Run the power to the lights from the battery through the fuse holders (15A per light should be fine). Trigger the relays with a leed to the accessory power from your radio.
Otherwise, I don't know about OEM DRL modules. Also, my way you will still have to turn on the headlights to use highbeams, but it will give you the DRL's. Good luck!
eckhart
May 28, 2009 05:43 PM
logan
Aug 16, 2008 12:57 PM
Avonlea22
Jan 23, 2008 11:44 AM
deserthonda
Jun 24, 2006 05:34 AM
eckhart
May 27, 2006 07:40 PM
