Drl
Old May 14, 2012 | 07:03 AM
rjsp's Avatar
Default Drl
I have a 1994 Honda Accord with daytime running lights. The issue is intermittent day time running lights, when they are working the high beams are both on, when they stop working.... and the headlights are turned on (with the switch), the right high beam is out, I have taken the drl out from under the dash, inspected the circuit board, resolderd a couple of the relay pins, and still no change, I know the bulb is good, as I switched them. Has anyone come across this specific problem, and found a common solution?????
Thanks in advance
Old May 14, 2012 | 10:17 AM
Even if the high beam bulb lights, it may be bad causing your DRL problem if you already checked the DRL module. Your car is probably a Canadian Accord, as USA Accords didn't have DRL in your model year.
eckhart
May 28, 2009 05:43 PM
Avonlea22
Jan 23, 2008 11:44 AM
surajsss
Sep 14, 2007 08:37 AM
deserthonda
Jun 24, 2006 05:34 AM
eckhart
May 27, 2006 07:40 PM
