Dual Climate Control Heat Problem
Old Feb 4, 2014 | 02:56 PM
Rachel Mulhall's Avatar
Unhappy Dual Climate Control Heat Problem
Hi All,
I'm a new member here and I've been dealing with this problem for the past few months. I have a 2009 Honda Accord EX-L with 42K miles. When I start my car in the morning, if I try to adjust the temperature on the driver's side, my car goes into "Lo" but I can still adjust the passenger side when in dual mode. It only happens when it's freezing out and I'm usually able to adjust the driver's side after 20 minutes of heating up/ driving. I've had a coolant flush which didn't resolve the problem. Once the car is in "Lo" mode, I cannot change the temperature even if I shut off A/C, turn Auto on or off. I've tried the self-diagnosis but it remains blank.
Anyone have a similar problem or know what might be the cause.
It appears electric to me, since I have heat if I don't touch the temperature control gauge.
Thanks in advance!
Old Feb 4, 2014 | 04:12 PM
Welcome to the forum.
I already read some of your posts at another forum. So, you did the following already, correct?
  • Low on anti-freeze/coolant. Filled and okay for about 2 weeks, then same problem.
  • Coolant flushed
  • Self diagnostic shows no codes
In the service manual, it states if the driver's and passenger's side vent temperatures varies by more than 20 degrees F, the probable cause are the recirculation control door or the air mix door is malfunctioning. Troubleshooting would be a tests of the following:
  • recirculation control motor
  • driver's air mix control motor
  • passenger air mix control motor (this sounds to be working properly)
Old Feb 5, 2014 | 10:56 AM
Hi, thank you for your response. The recirculation vent does make an awful sound when pressed when the driver side is stuck at the "Lo" temperature. I will troubleshoot those later today and let you know what I find. Thanks.
Old Feb 5, 2014 | 11:16 AM
You'll need someone with access to the service manual to perform the tests.
The driver's air mix control motor is under the center left side of the dash and the recirculation control motor is located behind the passenger glove box. If one of them is the problem, they are not difficult to replace; only a few screws hold them on.
Old Feb 19, 2014 | 06:23 AM
ajconte2014's Avatar
Default Same issue
Rachel I have the same issue. Were you able to fix it?
-Arthur
Old Feb 19, 2014 | 07:08 AM
Sorry to hear you have the same issue! What year is your car? I haven't been able to look into the problem as I've been traveling the past few weekends and with sunset at 5:30pm doesn't allow for much weekday time. Let me know if you find solutions in the meantime.
Old Sep 23, 2022 | 07:30 AM
Essexhammer's Avatar
Default Any fix
Just reading this thread as I have the same issues, was anyone able to resolve the problem? Thanks!
kaotiklivin4eva
Mar 31, 2013 04:31 PM
milehighaccord
Jan 8, 2013 10:04 AM
patsfanatic
Jul 5, 2010 03:09 PM
Detlef10
Jul 24, 2009 08:26 AM
greenbean
Sep 21, 2007 03:14 PM
