| 93jdmcb7 |
Jan 12, 2013 10:41 AM |
Ecu fuse blows in first gear at full throttle
yesterday morning i was trying to adjust my distributor because i noticed i heard it pinging at low rpm so i rotated it clockwise. After the fact i took it like a half block down in full acceleration in first gear and it completely died and did not want to crank over. I checked for spark and no spark. So i checked my distributor and ignition coil at autozone and they said they were fine. So i went back and checked the fuses under the hood and noticed the ecu fuse was no good. So i changed it and it happened once again. so i tried a 20 amp and this time it felt like it cut out at 4000 rpm but kept accelerating. but only in first gear i have this problem. every other gear under full acceleration it runs great. i put a 40 amp fuse and it ran fine until i lowered the idle with the screw on the throttle body and its been having the same problem since. What can be causing this? :confused:
