Ecu fuse blows in first gear at full throttle
Old Jan 12, 2013 | 10:41 AM
93jdmcb7's Avatar
Default Ecu fuse blows in first gear at full throttle
yesterday morning i was trying to adjust my distributor because i noticed i heard it pinging at low rpm so i rotated it clockwise. After the fact i took it like a half block down in full acceleration in first gear and it completely died and did not want to crank over. I checked for spark and no spark. So i checked my distributor and ignition coil at autozone and they said they were fine. So i went back and checked the fuses under the hood and noticed the ecu fuse was no good. So i changed it and it happened once again. so i tried a 20 amp and this time it felt like it cut out at 4000 rpm but kept accelerating. but only in first gear i have this problem. every other gear under full acceleration it runs great. i put a 40 amp fuse and it ran fine until i lowered the idle with the screw on the throttle body and its been having the same problem since. What can be causing this?
Old Jan 12, 2013 | 11:02 AM
I would suspect an ECM board fault is causing high drain. If you keep increasing the amperage, you may be rewarded w/ a fire. Suggest removing and examining the ECU. You may need a replacement.
If you adjusted the throttle plate idle stop screw, you made a mistake. This is not to be adjusted. Idle is adjusted w/ the throttle body bypass bleed screw on TDC of throttle body intake. Adjust idle w/ IACV disconnected to 600 +/- 50 rpm. Reconnect IACV and reset ECM to correct engine code caused by disconnecting IACV.
Old Jan 12, 2013 | 01:22 PM
I'd also say that a timing light should be used - be sure to use the proper procedure so you are not fighting the ECU - to set the timing
4x4aholic
Nov 3, 2013 06:26 AM
Tyler durden
Oct 6, 2012 01:38 PM
Mdschmidt
Oct 24, 2010 07:37 PM
H22cb7
May 14, 2008 01:55 PM
paulm
Aug 3, 2006 04:00 AM
