2002 Honda Accord LX a/c blows cool then blows warm
Old Oct 31, 2013 | 01:14 PM
4x4aholic's Avatar
Default 2002 Honda Accord LX a/c blows cool then blows warm
Noticed about week ago that there was a noise inside of the car. It sound like a hissing sound but it goes from light to little louder like its building up. then stops.
Then This morning my Girlfriend calls and says that the a/c blows cold then blows warm. And switches back and forth from cool to warm. Can anyone help me figure whats going on here?
2002 Honda Accord LX 4cyl
210,895 miles
Old Oct 31, 2013 | 05:14 PM
Performance suggests low refrigerant charge. When compressor quits, pressure drops quickly and no cooling. This will usually result in frequent cycling of compressor on/off w/ a period of 5-10 secs, where it should be 15-20 secs, depending on temperature and heat load.
Unless you intend to DIY, time to get some professional help to check system pressures and diagnose problem.
It could also be an intermittent compressor clutch due to excessive clutch gap. This will sometimes cause erratic cooling, then no cooling.
If you want to DIY, start w/ a very good description of what's happening w/ the compressor; frequent on/off or erratic w/ long periods of OFF.
Old Oct 31, 2013 | 06:36 PM
4x4aholic's Avatar
Thanks for your reply,
I plan on doing this myself. When my gf gets home ill take a look at it and see what it is doing. Hey looks like we both stay in Katy TX. LOL.
Old Nov 1, 2013 | 11:11 AM
4x4aholic's Avatar
Ok.. so heres what the car is doing. the clutch on the compressor kicks on as soon i turn the a/c on. And stays on for bout 15 sec the the clutch goes off for bout 15 secs. Today i keep the car and i haven't has the problem of the a/c going warm. So maybe it just has a mind of its own. lol.
Old Nov 1, 2013 | 03:21 PM
Sounds OK if cooling is acceptable.
If clutch gap or compressor relay issue, it will likely get worse as weather gets hotter.
Old Nov 3, 2013 | 06:26 AM
4x4aholic's Avatar
OK thanks.. ill keep an eye on things. if it gets worse ill check the compressor gap or relay. As of right now it hasn't gone from cold to warm for me. Thanks for your time and response.
Cbr1000f
Jun 21, 2013 02:46 PM
MHFry1
Jun 18, 2013 05:46 PM
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
jimshady
Sep 30, 2009 02:46 PM
74joe74
Jul 2, 2009 07:26 AM
