EGR cleaning
So I cleaned out my EGR ports last night. It was actually a lot easier than I had thought it was going to be. It would have been even easier if I had taken my front strut bar off, but I worked around it. There was a HUGE build up of carbon crap in there, I doubt if they have ever been cleaned, and this car has almost 191k miles on it. So now the car is running quite a bit better than it was. However, my check engine light still comes on when I first start up the car. It only happens when I start up the car after it has cooled down. So I guess I need to see if Advance Auto Parts will run the scan and tell me what code I have. Is there a directory of engine codes somewhere on the net?
RE: EGR cleaning
lots of code lists, your best bet is to find out what the code is and then click on the search button on this forum, chances are it'll show you the answers you need.... if not post the code and we'll help you out
RE: EGR cleaning
on our DIY section there is a post ( Honda obd trouble codes ) .... you did clear the ecu ,,,right ??
RE: EGR cleaning
Clear the ECU? No. I dont even know how to do that lol. Are you saying that its still got the code in there from when the ECU ports were clogged?
RE: EGR cleaning
correct, if you didn't clear the ecu it will still report the code (even if it's fixed) until the code is cleared.... just take it to the local auto parts store and have them clear it.
RE: EGR cleaning
did you clean the egr valve as well?
RE: EGR cleaning
I cleaned the ports and the runners per Hondadude's instructions that I found on this forum. It didnt say anything about the valve, so I didnt do anything to it. Its running about a hundred times better than it was, I know that. Where is the EGR valve located, and should I tear into it again to clean it?
RE: EGR cleaning
ORIGINAL: poser_pilot6 Clear the ECU? No. I dont even know how to do that lol. Are you saying that its still got the code in there from when the ECU ports were clogged? |
RE: EGR cleaning
poser_pilot6, What year is your accord???
RE: EGR cleaning
It's a 94 LX 4Dr.... (I read one of his old posts) He really should put that in his signature though *LOL*
