EGR Valve
Old May 21, 2019 | 01:37 PM
delcogod's Avatar
Default EGR Valve
I have a 98 Accord EX 4 door, 4cylinder, 5 speed with 280,000 original miles. ( 2nd owner, have known car since new). I'm chasing the dreaded idle surge and found that my EGR valve has an open between pins 1 & 3 which the Haynes manual says is bad. The bellows would not move after I removed it. I dumped mouse milk on it and it moves slightly now. Does anyone know the deflection length of a bellows for this car? Car runs great except for the surge which I'm troubleshooting. Have changed IAC, verified coolant, and replaced PCV valve which was stuck. Thanks
Old May 22, 2019 | 03:07 PM
The Toecutter's Avatar
I don't know how much lift it's supposed to have, but my wife's 2000 Accord LX 4 cylinder AT car had the valve go bad (at 223K miles), and it surged about 400 rpm when it did so. It got kind of annoying. I ended up removing the upper plenum, thinking it had clogged ports. In then end I just replaced the valve with 1 from the zone, and it's been good now for 4 years.
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
Nov 12, 2011 12:54 AM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
RJLhonda
Sep 9, 2008 01:05 AM
