EGR Valve Removal
I got the notorious P0401 code and am trying to fix the problem. I cleaned up the EGR ports and the plates but I couldn't get the EGR Valve off to replace the gasket. I got the nut closer to the Valve Cover off but the nut next to the Throttle Body I am having an issue with.
A Wrench didn't do any good, I tried getting it with a socket attached to an extension but to no avail and a socket attached to a flexible adapter attached to a ratchet didn't fit. Unfortunately the nut got a bit stripped on the top. Is there any other tool, socket or adapter that will help me remove this stubborn nut? |
I've used a "crows foot" on my 95 before. I think there a swivel sockets that might work as well.
I bought a crowfoot set and hopefully that'll do it.
On the bright side though, I cleared the code and it hasn't come back, the car also idles much better. Where would one buy Swivel Sockets? I went to Autozone and I don't think I saw those. |
Damn, the nut is stripped and the crowfoot didn't work.
One of my auto tech buddies offered me some help since he has far more tools than I do. I'm definitely going to pass by the Hardware store later to buy a nut though. |
1 Attachment(s)
I'm sure there are several places that do sell them I got a 3/8 set from Sears (carftsman)-10 thru 19 but no 14 :(, so I got that size 3/8 made by Blackhawk, I also have 1/4 drive 8, 10, 12 made by Blackhawk....at the time carquest sold Blackhawk tools, I think they have another line now.
Found this from powerbuilt?? Good luck, let us know how it works out. |
I wouldn't be overly concerned about pulling the EGR valve itself.
The majority of the blockage is the ports under the runner plate you have already cleared. http://hondadude.webs.com/95%20Accor...5AccordEGR.htm |
@poorman212: I'll look into those. Those may or will come in handy eventually. :D
@hondadude: Oh alright, I just wanted to replace it since I doubt it has been replaced in a very very long time but I guess it can be done another day. I'll focus more on replacing the rotors and brakes since I am going out of town this weekend and don't want to die. |
