-   -   At the end of my rope (https://www.hondaaccordforum.com/forum/general-tech-help-7/end-my-rope-625/)
fireman_415 May 31, 2005 02:46 PM
I have a 92 Honda Accord That I love. I had no problems out of this car in 3 years, the clutch went out in it and I had a shop put a new clutch in. When I recieved the car back, I drove down the road and all the dash lights came on and the car shut down and stereo shut off and then it all would go back to normal. It has been in 3 differant shops and no one knows what it is. They keep working on the grounds and same thing. Now the car is broke down again, When you push the clutch in it makes a clicking noise under the dash and won't turn over and when you let the clutch out it will crank over but will not start.....I am about to explode.....PLEASE HELP.
6thgen May 31, 2005 03:01 PM
RE: At the end of my rope
That's pretty messed up, it does sound electical though...never had any problems like that though, there are a few technicians on here that may be able to help. It's harder to diagnose weird problems with out ahve access to the car (to watch the problem occur.)
fireman_415 May 31, 2005 03:05 PM
I understand but I have had this car into a local Honda dealership and 3 electric shops and still same problem, know one knows.
6thgen May 31, 2005 03:16 PM
Sounds like a lot of $$$ for no real progress.
Evlampius May 31, 2005 04:46 PM
ORIGINAL: fireman_415
mmm how about an alternator faiure.
do you know how to diagnose bad laternator and/or battery?
fireman_415 May 31, 2005 05:00 PM
At one of the electric shops they had replaced the alt. with a brand new one.
fireman_415 May 31, 2005 05:24 PM
Oh and the batt. is new also.
Evlampius May 31, 2005 09:37 PM
then you have an open wire circuit somewhere -
Theres a switch that tells the car that the clutch is depressed so it's OK to start.
Check that circuit.
I'm not sure this problem is related to the clutch replacement....but everything is possible
fireman_415 Jun 1, 2005 11:33 AM
Is the switch you are talking about, is it the neutral safety switch or do you know which switch, The only reason I ask is because I have asked this question to one of the Honda tech's at the local Honda dealership and his response was in 16 years I have never had one go out , I do not believe they had checked it.
Burn69 Jun 2, 2005 02:27 AM
Sound like a short problem of some kind....
