jehanzaibmansoor |
08-30-2022 04:43 AM |
Engine problem with AC on.
2 days back, I saw a battery sign appearing on my car, even though car was starting fine everytime after checking it twice or thrice. But after certain time, I switched AC on. AC was working fine, and I put reverse gear to take it out of parking. But acceralation was on free flow, the car wasn't moving at all. I was a bit shocked, turned off the car after turning AC off. And restarted it after a while, it started off well as normal, and I reversed it which happened as normal. Turned the AC on, woah again no movement, seems like gear is neutral on Drive mode. I turned off the AC and the car started moving as normal. Next day I changed the battery but still battery signal is still appearing and same issue is happening with AC on. Will go for computer test today.
If anybody have faced such issue, what could be the problem??
