engine stalls
Old Jun 8, 2008 | 06:55 PM
saltine251's Avatar
Default engine stalls
my engine stalls or dies as soon as you give it gas. if it dont die it will run fine.
any idea what the problem is?
97 ex jdm vtec
Old Jun 8, 2008 | 10:25 PM
hondadude's Avatar
Default RE: engine stalls
Do you have a CEL? or have you checked for stored codes?
Can you give any more info? last tune up? Timing belt?
What is the idle RPM?
can you unplug the IACV and see if the idle drops 200 RPM
Old Jun 9, 2008 | 05:25 PM
saltine251's Avatar
I had a jdm motor put in last week. put new water pump, all new timing gears and belts and all seals.
new plugs and wires ,air filter.
the only code its sending is 1 o2 sensor the car idles around 700 rpm
97 a/t jdm vtec f22b
lionj
Jul 22, 2007 11:21 PM
verno
Jan 18, 2007 09:40 PM
emaxxman
Feb 19, 2006 03:07 AM
BDN54
Oct 25, 2005 10:15 PM
NewfieTJ
May 11, 2005 12:53 PM
