Engine Swap Question
Old Jan 11, 2008 | 11:43 PM
markjw's Avatar
Default Engine Swap Question
I hope I dont get flamed here,I'v read thru the archives and cant find a definite answer,but I need to ask this question before I do something dumb. I'm very new to accords...I bought a damaged '87, carburated, 4door, 5 speedaccord LX from a girl I know. Only thing good is the5 speed transand engine. I am on my way to Portland tomorrow to buy a '89, carburated, 4door, Automatic Trans accord DX, Blown Headgasket. My question is, Will I be able to simply swap the good motor from the "87 To the "89?Just the Motor,not the trans.Any advice or info Greatly appreciated.
Old Jan 12, 2008 | 09:50 AM
markjw's Avatar
Default RE: Engine Swap Question
I'm pretty sure the motor in my '87 is a 2.0.. I'm pretty sure the motor in the "89is also a 2.0. I guess what I really need to know is there any diffrences between the two motors, beings ones mated to a manual trans and the other is mated to a standard trans?
Old Jan 12, 2008 | 09:53 AM
BlkCurrantKord's Avatar
As long as the motors are the same I don't see why there'd be a problem.
Old Jan 12, 2008 | 09:58 AM
HondatechAV6's Avatar
i'm not sure, but the best way to be 100% sure would be to look at the engine codes. if they are the same then you are good to go! if you can post both vin numbers i can look up the engine codes and tell you if they are the same.
Old Jan 12, 2008 | 10:16 AM
markjw's Avatar
ORIGINAL: HondatechAV6
Ok, Give me a few to call the Lady in Portland and get it..I have mine out in the backyard..Thanks.
Old Jan 12, 2008 | 10:27 AM
markjw's Avatar
Well, she didn't answer her phone. Here's my Vin. Code. JHMCA5525KC001646
Can you tell me which charecters need to match with her vin. code? Hopefully it works that way.Thanks a million.
Old Jan 12, 2008 | 10:34 AM
i'm not matching vin characters. i'm looking what engine originally came with that vin number
yours has this engine in it:
A20A1
when you get her vin number we can check her engine and see if it's possible.
Old Jan 12, 2008 | 10:42 AM
markjw's Avatar
Thanks for the Help...Least I know what engineI have now..I'll try and call her again.
Old Jan 12, 2008 | 11:35 AM
markjw's Avatar
I got it!!!! Vin For the '89 accord: JHMCA5626KC119106
Old Jan 12, 2008 | 11:43 AM
A20A1! you both have the same engine, good luck!
