engine vibration HELP PLEASE!!!
Old Aug 10, 2007 | 12:13 PM
ihaveanaccordtoo
Default engine vibration HELP PLEASE!!!
About two weeks ago my CD7 SE(F22b2) developed an engine vibration just out of the blue.
It shakes at idle but if i bring the RPM's to about 900 the vibration stops. it feels like my car is a giant back massager. I checked the engine mounts and they checked out good, so I replaced the spark plugs, distributor cap, PCV valve and washed out my AEM dryflow filter and it did not help, what do you guys think is wrong? thanx!
Old Aug 10, 2007 | 12:48 PM
finch13's Avatar
Default RE: engine vibration HELP PLEASE!!!
what rpm does it idle at now? should be around 750 and you may need to adjust it.
p.s. - this forum section is for improvement suggestions to the forum, bot help. try the "general tech help" section next time. mods: feel free to move this
Old Aug 14, 2007 | 05:19 PM
kevcann3's Avatar
let me ask do you have a aftermarket intake or muffler if so when you do stuff to the air flow system you need new motor mounts been there done that....
Old Aug 15, 2007 | 08:35 PM
ihaveanaccordtoo
ok but why now why not 2 years ago when i put all the stuff on the car
Old Aug 16, 2007 | 09:26 AM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: kevcann3
[sm=WTFsgign.gif]are you talking about? I havenever heard of this before.
Old Aug 16, 2007 | 04:26 PM
finch13's Avatar
00AccordLX5spd, didn't you know that a new intake ads at least 200hp and will bust your mounts to dust!
Old Aug 16, 2007 | 10:05 PM
myrtle71590's Avatar
hahahaha
Old Aug 21, 2007 | 10:42 PM
deserthonda's Avatar
i would take a real close look at the rear mount ,, also make sure that there is vacc at the mount diaphram when engine RPM is below 700,,, I am assuming car is AT .
Old Aug 31, 2007 | 02:24 PM
Hen_Rock
I have a 2000 LX, and it developed a rattling/vibrational sound when it would idle and when I decelerated while going at a slow speed. Turns out my catalytic converter went bad. I spent a small fortune getting it replaced and it fixed the problem, but man....that cat con was expensive as hell!
Old Sep 2, 2007 | 05:09 PM
finch13's Avatar
Hen_Rock, had a similar issue. My cat would have a really tinny sounding rattle at idle and deceleration and I just removed the lower heat shield on it and it went away. What could it have hurt? It was only shielding the pavement.
