Erratic Engine Idle
Old Mar 19, 2011 | 05:32 PM
campbmic's Avatar
Default Erratic Engine Idle
Hey guys Im new to the forum. I bought a 91 Accord EX Station Wagon at a police auction a few months ago. Put a new battery in it and it started right up. The only problem is the idle instantly shoots to 3k then drops to 1.5k then shots back up to 3k and drops. This is just constantly going on the entire time. Like a ghost is revving the car haha.
Anyways, aside from a exorcism what else could fix this?
Thanks!
Old Mar 19, 2011 | 08:40 PM
Old Honda Dude's Avatar
Default Fast Idle Valve
Looking into engine bay . Look at intake manifold. on the right side ( drivers ) and vertical with two small coolant hoses at bottom, is the fast idle valve. This is what controls what your describing. The coolant may not be getting to it. Possible low coolant or restriction. if ok there then replace the fast idle valve.
Old Mar 19, 2011 | 10:15 PM
You can also remove the cover to the fast idle valve (FITV) and tighten the plunger. There is a writeup in the DIY section about this.
Raz93
Jul 8, 2009 07:13 AM
delgadoe
Feb 3, 2009 04:58 PM
Tai_Boi
Mar 29, 2008 01:08 AM
Planefreak
Oct 28, 2007 11:09 PM
mastar91169
May 11, 2007 10:36 AM
