Erratic idle
I have a 98 EX, manual. I was having issues with power and deducted that it was the throttle position sensor. I decided to buy a used throttle body off ebay (40bux) and it came with all the sensors. I literally just dropped it in.
It seems everything is much more crisp except for one problem. My idle is bouncy as hell. Before i was idling at a smooth 800 rpm. Now it jumps between 1k and 2.1k constantly. I went for a drive and noticed that i'm actually slightly accelerating in gear if i drop below 1500 rpm.
What do i need to do??
Its also important to note i didn't use a throttle body gasket. I forgot to get one and decided to RTV silicone that hoe.
Look in the DIY Answers section for a post by me about setting the base idle.
And... is it possible that the RTV has oozzed into the little air passageway & blocked it off?
Did you use "sensor-safe" RTV? Normal silicone releases silanes during curing, which is sudden-death for O2 sensors.
Raz93
Jul 8, 2009 07:13 AM
