Erratic idle
Old Nov 4, 2011 | 08:45 PM
hispanicpanic's Avatar
Default Erratic idle
I have a 98 EX, manual. I was having issues with power and deducted that it was the throttle position sensor. I decided to buy a used throttle body off ebay (40bux) and it came with all the sensors. I literally just dropped it in.
It seems everything is much more crisp except for one problem. My idle is bouncy as hell. Before i was idling at a smooth 800 rpm. Now it jumps between 1k and 2.1k constantly. I went for a drive and noticed that i'm actually slightly accelerating in gear if i drop below 1500 rpm.
What do i need to do??
Its also important to note i didn't use a throttle body gasket. I forgot to get one and decided to RTV silicone that hoe.
Old Nov 5, 2011 | 02:44 PM
Be sure the coolant is bleed properly. Then search for vac leaks, many methods to do this....if you need some of those let us know.
Old Nov 6, 2011 | 04:40 PM
Look in the DIY Answers section for a post by me about setting the base idle.
And... is it possible that the RTV has oozzed into the little air passageway & blocked it off?
Did you use "sensor-safe" RTV? Normal silicone releases silanes during curing, which is sudden-death for O2 sensors.
Old Nov 7, 2011 | 04:49 PM
Figured it out. the rtv was providing a ****ty seal, and i didn't exactly scrape all the old gasket off... man i was lazy. SPent 2 dollars on the gasket and fixed the problem.
Old Nov 7, 2011 | 08:05 PM
Thank you for the update.....too many times we never know how it turns out/
Raz93
Jul 8, 2009 07:13 AM
delgadoe
Feb 3, 2009 04:58 PM
Tai_Boi
Mar 29, 2008 01:08 AM
Planefreak
Oct 28, 2007 11:09 PM
mastar91169
May 11, 2007 10:36 AM
