Exhaust parts misfit
Old Apr 12, 2012 | 04:47 AM
Bazz's Avatar
Default Exhaust parts misfit
1997 Honda Accord LX; 5 door (station wagon);
F22B2 engine (4 cylinder); KA5MT (5 speed manual transmission)
I have replaced these exhaust system parts - middle pipe, B pipe, and muffler - with new Honda OEM parts as indicated on the schematics and parts list provided on the Honda estore website and by Honda dealers.
The outlet on the B pipe is 49mm outside diameter (the A pipe, middle pipe, and B pipe are all 49-50mm OD) but the pipe on the muffler is 45mm OD.
The gasket (18229-SS1-000) which came with the muffler is 45mm ID. In other words, Honda apparently intends this 45mm muffler (with the 45mm gasket) to match with a 45mm B pipe. The problem is the B pipe they indicate is 49mm.
Part numbers are as follows:
Middle pipe: 18201-SV4-A31
B pipe : 18220-SV1-C70
Muffler : 18030-SV5-506
QUESTIONS:
1.Has Honda made a mistake in indicating this muffler with 45mm pipes for this car? (Everything else is 49-50mm) 2.What is the diameter of the B pipe and the muffler supposed to be? I know the dimensions of my new parts by measuring them but I don't know what they are supposed to be. 3.If I have the right B pipe and muffler then what is the right gasket to make the transition from the 49mm B pipe to the 45mm muffler?
MY EFFORTS TO SOLVE THE PROBLEM:
Since the B pipe is an SV1 part I tried an SV1 gasket (18229-SV1-003). It was a little loose on the B pipe and I had to hammer it into the recess of the muffler flange. In other words it didn't work well - I got the joint bolted together but it is too tight. The Honda dealer wants me to try gasket #18229-SV4-A71 but he is not sure of its size. The Honda Parts Analyst could not give him dimensions on any of these parts to verify that I have the right parts - that they were labeled correctly. Honda Customer Relations could not give me dimensions and would not allow me to speak in any manner with their tech support people - they referred me back to the dealer. I suggested to Honda Customer Relations that parts dimensions should be available to owners and dealers.
Old Apr 12, 2012 | 10:02 AM
Roader's Avatar
Wagon exhaust systems are weird. Last year when doing some exhaust work I kept running into seemingly contradictory part diagrams at the aftermarket web sites (AP/Walker/Borla). Searching for a solution, I ran across this and bookmarked it:
"http://www.justanswer.com/honda/1yw71-1997-honda-accord-lx-wagon-vin-1hgce1827va006780-this.html"
Page down to how he ended up solving the problem using OEM parts:
The Honda Parts book had several incorrect part numbers for Pipe B on the 94 to 97 LX series. Bernardi delivered a pipe listed for a 2dr/4dr LX and it fit the car.
Hope this helps.
fatboy1185
19
Nov 21, 2010 12:47 AM
4reyes
Dec 3, 2008 11:49 PM
top end ms
Feb 14, 2008 12:35 AM
chadew
Nov 29, 2007 09:52 PM
