Expansion Valve Location for 90 Accord
Old Jul 7, 2008 | 04:19 PM
dsettlemoir
Default Expansion Valve Location for 90 Accord
Where is the expansion valve located on a 90 honda accord? Also, does anyone have a diagram?
Old Jul 7, 2008 | 07:05 PM
Default RE: Expansion Valve Location for 90 Accord
Expansion valve is attached to the evaporator under the dash. To access, you must discharge the system and disconnect both tubing connections on engine side of firewall, then remove the evaporator box from under the dash, after removing the glove box for access. Don't try removal w/o an Accord Shop Manual. Suggest downloading the 91 Accord Manual from hondahookup.com. See Online Manuals link under DIY.
Job is really pretty easy, especially compared to many US models which require dashboard removal to access the evaporator box. Replace all the orings on the expansion valve and temperature sensing bulb. They tend to dry out and leak, especially at the brass/aluminum joints. Lube w/ Nylog or other oring lubricant.
Probably a good time to replace all orings in the AC system connections, and install a new receiver/drier before vacuuming and recharging. You don't want any precious R12 to leak for a long time.
GIXER7502006
Sep 3, 2012 01:03 PM
cldoole
Jun 19, 2012 10:38 AM
jroe_28
Apr 15, 2009 07:15 PM
joeaksa
May 13, 2007 10:39 PM
ballistic
Aug 27, 2006 05:56 PM
