Sponsored by:
Sponsored by:
Antenna
Old 02-13-2012, 07:15 PM
rwyatt80's Avatar
Default Antenna
Hello,
I have a 96 accord 4cyl sedan that has no external antenna (only internal). I wanted to know where can I find the antenna assembly on the car. Also, where can I find the replacement part??
Old 02-13-2012, 10:55 PM
The antenna is part of the rear window.
What is the problem with your car? Have you done any work on it lately?
Old 02-14-2012, 12:24 AM
Are you wanting to install an outside antenna.?
That would be easy if your wanting to do that..
Old 02-14-2012, 01:46 AM
crispin's Avatar
I need to do something with my antenna as well.
The plug on mine was very small so I bought 2 different adapters from ebay and neither one fit. So out of desperation I cut the end of mine off (bad idea) and tried to make it work (it didn't)
I notice that my 95 donor car has an external antenna so I gues the hidden one was for 96 - 97 only.
Old 02-14-2012, 05:50 AM
rwyatt80's Avatar
The only work I had done recently was have the rear windshield replaced. The issue I am having is that reception absolutely sucks!! The reception was bad before the replacement.
I am not sure if I want an outside antenna. I assume it would be alot better than what I have now...
can the reception be fixed
Eauxkie
09-27-2006 08:18 PM
billyloon
07-30-2006 07:13 PM
msmiz
12-22-2005 09:05 PM
stigedis
12-04-2005 10:12 PM
pgopalak
12-17-2004 03:30 PM
Quick Reply: Antenna
