Fan Noise on 99 Accord V6 louder?
Old Dec 31, 2004 | 01:54 PM
Guest
Default Fan Noise on 99 Accord V6 louder?
60K miles and in mint shape but the fan 'noise' becoming more and more distinct practically a hum at this point.
It does not pull on the motor as far as the tach reads when in neutral or drive. Any ideas before
I go to the dealer blind? Thanks in advance!
Old Dec 31, 2004 | 09:10 PM
Default RE: Fan Noise on 99 Accord V6 louder?
Sounding like your bearing may be going out on your Water-Pump.
If you have a fan clutch on the front see if it wiggles back and forth, if it does then your bearing may be getting bad.
Also have you changed your timeing belt ever?
WheelBrokerAng...
Welcome to the forums[sm=smiley32.gif]
Old Jan 2, 2005 | 01:54 PM
RTexasF's Avatar
Super Member
Is it possible that a fan shroud or some item in/around the fans is vibrating when the fan is engaged? That would make the fan appear to be louder.
Old Jan 3, 2005 | 02:04 PM
Guest
thanks for the reply. Turns out the hum/fan noise was my alternator going. 60K miles and an alternator? must be the Florida heat I guess.
Old Jan 3, 2005 | 02:07 PM
Guest
thanks for the reply. I focused in on the areas of alternator, water pump etc..everything driven by the belt and as it turns out it was the alternator. Now I'm trying to find the procedure to reset the SRS warning light which goes on the fritz when you have an electrical situation I understand. If you know something I'd appreciate it. Thanks!
Old Mar 3, 2005 | 03:14 PM
99 EX V6
Sorry, I don't have the answer but just wanted to let you know that mine has 74,000 mile on it. My fan is pretty loud as well. When I'm idling, and the fan kicks on, the car shudders for a second, almost as if it is going to stall out. Good luck.
Old Jul 30, 2007 | 12:30 AM
emgomez
It souds like I also have the same problem. I havea 4 door sedan. My noise sounds like it is also getting louder, however the fan noise turns off when I turn off the AC. I don't recall this noise being this loud. Any suggestions would help. Is your noise always on including when you have the AC on?
renzovc16
Dec 14, 2012 04:38 PM
1999HondaAccordEXV6coupe
Aug 17, 2012 05:13 PM
anneinct
Jun 6, 2009 10:23 PM
Mark Broughton
May 14, 2009 05:25 PM
19Accord97
Oct 6, 2006 01:51 AM
