fans not turning on ON acura 96
I today I was making line on the international boder Mexicali/ Calexico Ca and I noticed my acura getting hot, I opened the hood and I noticed that no fans were working I replace some water needed and turned te a\c on and they never turned on. I made it to my house. tomorrow morning I will try to find out what is wrong. any recommendations about where to start?
RE: fans not turning on ON acura 96
Check out the 'Do it Yourself Section,' there is a post from Deserthonda about if your car is overheating, I would read that over real well. Also try jumping your fans to make sure they work, I doubt both fans would die at the same time but it is better to check. Also check your fuses and relays.
Update, fans work with the A/C but they do not turn on with the car idle, both hoses upper and lower are at the same temperature, radiador fluid is to the top, and water pump seems to work. so what could it be?
