fans not turning on ON acura 96
Old Nov 25, 2006 | 01:54 AM
depezhe
Default fans not turning on ON acura 96
I today I was making line on the international boder Mexicali/ Calexico Ca and I noticed my acura getting hot, I opened the hood and I noticed that no fans were working I replace some water needed and turned te a\c on and they never turned on. I made it to my house. tomorrow morning I will try to find out what is wrong. any recommendations about where to start?
Old Nov 25, 2006 | 02:04 AM
Slusher's Avatar
Default RE: fans not turning on ON acura 96
Check out the 'Do it Yourself Section,' there is a post from Deserthonda about if your car is overheating, I would read that over real well. Also try jumping your fans to make sure they work, I doubt both fans would die at the same time but it is better to check. Also check your fuses and relays.
Old Nov 25, 2006 | 09:20 PM
depezhe
Update, fans work with the A/C but they do not turn on with the car idle, both hoses upper and lower are at the same temperature, radiador fluid is to the top, and water pump seems to work. so what could it be?
huhdo
Aug 30, 2012 09:06 PM
stephenml
Nov 2, 2009 09:55 AM
ronski
Aug 19, 2009 10:06 PM
SteveZ
Jan 5, 2008 05:08 PM
Kool Kid
Nov 26, 2007 08:55 PM
