First Accord Problem - It shuts off
Old Jun 1, 2009 | 05:14 PM
volley13
Default First Accord Problem - It shuts off
Here's the car's description:
1998 Honda Accord LX, 4 cyl
approx 120,000 miles
Recently, my son said he was driving, came to a stop light, and when he stopped, the car just shut off. He started it, and kept going. About 10 days later, the same thing. This time, just before coming to a full stop, the car shuttered, then shut off. He restarted and took off.
I know it was time for a tune up so I took it to the mechanic. They said they'd have to catch the "shut off" when it happened to figure out what was going on. Of course, it didn't do it but I had the tune up done anyway. About a week later, it happened again.....any ideas on what this could be?
thanks....
Old Jun 1, 2009 | 05:17 PM
deserthonda's Avatar
any codes?? ignition switch recall done ??
Old Jun 1, 2009 | 08:45 PM
Sufler's Avatar
Fuel pump relay?
Old Jun 2, 2009 | 09:35 AM
Originally Posted by deserthonda
ignition switch ??
See if he can make it happen by wiggling the key.
Old Jun 2, 2009 | 10:22 AM
volley13
Thanks for the responses....
1. No codes detected during the tune-up process.
2. Ignition switch recall done?? No, this has not been done. Would this be a free recall item from Honda? Can you explain how this could be a possibility? Thanks.
I'll have my son try the wiggle key thing when he gets home today. As for the fuel pump relay,??? Other than the normal wear & tear items, and having the timing belt replaced some years ago, like a lot of Hondas, the car has been trouble-free.
Thanks again.....
Old Jun 2, 2009 | 10:54 AM
Honda has recalled the ignition switches. ANY dealer can look up your VIN & tell you if it qualifies, & tell you if it's already been done on that car. If you're lucky, it'll be FREE.
Old Jun 2, 2009 | 11:03 AM
00AccordLX5spd's Avatar
Registered User
What is on your son's keychain? The reason I ask is: at work in order to enter the building we have these key "fobs" that go on your keychain. You swipe it in front of a pad and the door opens for you. The "fob" emits a little radio signal that can interfere with the anti theft chip in car keys. My car was shutting off intermittently and I figured out that the fob was the culprit. I removed the fob from my keys, and the problem went away.
Also when the car shuts off does everything shut off? Or does the radio, ac, etc stay on and the engine is just not running anymore?
Old Jun 2, 2009 | 01:51 PM
MagicOPromotion's Avatar
Default First Accord Problem It shuts off
When I first start my car it will completely die within 3 mins. Its like someone turned the key off cooling fans stop too. No sputtering or anything, just shuts down. I hardly ever drive the car and noticed it a couple months ago. It starts back up and after driving a while it wont do it again? Its my 94 Z28. Anyone have any ideas??
_______
=== XRumer 5.0 Palladium RULEZ! ===
Old Jun 2, 2009 | 07:39 PM
volley13
No key fob or anything on his keychain. When the car shuts off, things like the radio, a/c, etc. do remain on.
Old Aug 9, 2009 | 08:48 AM
HGBOONE
Did you ever find out what was wrong with your son's car? My accord is doing the same thing. The only thing unique is that it never shuts of if it has at least 1/4 tank of gas. I suspect fuel pump, but I do not know how to be sure.
