Flaky Side Mirror
My driver’s side mirror control is being flaky. It works to control it from left to right but not up and down. Sometimes it will start working again on its own. Usually, if I want to adjust the mirror up and down, I have to open the window and do it manually. The control works fine for the passenger side mirror. I’m thinking of trying to spray some contact cleaner in the part of the control that switches from left to right and/or trying to spray some lube (silicone or something) down behind the glass on the actual mirror. Has anybody else experienced this? What did you do to fix it? Thanks in advance.
I have noticed at times that my 94 EX will only move laterally, if I adjust the up/down to another position. I usually can track to desired postion w/ a little extra effort.
A new power window is relatively inexpensive, although matching color may be more expensive. Some use black and leave it unpainted. good luck |
Do you hear the motor working when you try to aim the mirror up & down? I think the mechanism is connected with ball/socket type connections, any maybe it just snapped out?
(Post 336723)
A new power mirror is relatively inexpensive, although matching color may be more expensive. Some use black and leave it unpainted.
Originally Posted by JimBlake
(Post 336829)
I'd test the switch before replacing the unit.....if you are not sending power to the mirror, what is the new one going to do?
(Post 337021)
The 4-way rocker switch might be OK, but the toggle that selects right vs. left side mirror might be open-circuit. Or some other flakiness in the wiring.
(Post 337058)
I finally took the panel off to look at my issue with the door lock. When I reconnected the mirror, I hit the connector with some contact cleaner and dielectric grease. Now it's working!
Keep your finger crossed.
Thanks for the follow up. |
