Flaky Side Mirror
Old Dec 6, 2013 | 03:19 PM
Rob2000AccordLX's Avatar
Default Flaky Side Mirror
My driver’s side mirror control is being flaky. It works to control it from left to right but not up and down. Sometimes it will start working again on its own. Usually, if I want to adjust the mirror up and down, I have to open the window and do it manually. The control works fine for the passenger side mirror. I’m thinking of trying to spray some contact cleaner in the part of the control that switches from left to right and/or trying to spray some lube (silicone or something) down behind the glass on the actual mirror. Has anybody else experienced this? What did you do to fix it? Thanks in advance.
Old Dec 6, 2013 | 08:48 PM
I have noticed at times that my 94 EX will only move laterally, if I adjust the up/down to another position. I usually can track to desired postion w/ a little extra effort.
A new power window is relatively inexpensive, although matching color may be more expensive. Some use black and leave it unpainted.
Old Dec 9, 2013 | 10:25 AM
Do you hear the motor working when you try to aim the mirror up & down? I think the mechanism is connected with ball/socket type connections, any maybe it just snapped out?
Old Dec 9, 2013 | 12:59 PM
A new power mirror is relatively inexpensive, although matching color may be more expensive. Some use black and leave it unpainted.
I didn't realize how inexpensive they are. I went on rockauto.com and they start around $25. May have to get one.
No, I don't hear the motor when aiming up and down.
Old Dec 11, 2013 | 05:42 PM
I'd test the switch before replacing the unit.....if you are not sending power to the mirror, what is the new one going to do?
Old Dec 11, 2013 | 07:06 PM
I'm thinking that since the right side mirror works with no problem with the same switch, that the switch is okay.
Old Dec 12, 2013 | 06:59 AM
The 4-way rocker switch might be OK, but the toggle that selects right vs. left side mirror might be open-circuit. Or some other flakiness in the wiring.
Old Dec 12, 2013 | 03:21 PM
Okay, I think I'll take the door apart and see if anything looks awry. I'll try some contact cleaner on the switch and see if that helps.
Old May 6, 2014 | 11:18 AM
I finally took the panel off to look at my issue with the door lock. When I reconnected the mirror, I hit the connector with some contact cleaner and dielectric grease. Now it's working!
Old May 7, 2014 | 08:18 AM
Keep your finger crossed.
Thanks for the follow up.
inthedump
Aug 7, 2011 07:41 AM
iimzii85
Nov 1, 2010 01:16 PM
ndp
Jun 7, 2009 05:23 PM
JimBlake
Feb 18, 2009 09:27 AM
rose92
Jan 9, 2006 11:23 AM
