Flashing "D"
Old Aug 12, 2006 | 05:35 AM
larry91403
Default Flashing "D"
For some reason - once in awhile - the "D" flashes on the dashboard. It does this in park or in drive. The only way to get it to stop is to turn off the car and then turn it back on again. Anyone have any idea why this happens?
Old Aug 12, 2006 | 12:17 PM
mbo1985's Avatar
Default RE: Flashing "D"
It means the transmission is detecting a problem. I believe it stores the code in memory so if you scan for codes you should be able to see what's wrong.
Old Aug 12, 2006 | 12:50 PM
deserthonda's Avatar
Larry..........you need to do 2 things before we can properly help you
# 1 .. input the year and model of the car you need help on,,,,input it on your signaturte so we can all see it
# 2 Like MBO says you need to read the code and post it here ,, without it , it is a guessing game and we do not want to fix your car by taking guesses
Old Aug 12, 2006 | 11:27 PM
larry91403
It is a 2006 Honda Accord - how do I read codes?
Old Aug 13, 2006 | 01:29 AM
YeuEmMaiMai's Avatar
unless you got 36K or more miles on it, go staright to dealer.....
Old Aug 13, 2006 | 02:01 AM
ORIGINAL: YeuEmMaiMai
absolutely do not waste any time.. call the dealer on monday and set up an appointment
Old Aug 13, 2006 | 01:33 PM
mbo1985's Avatar
serisouly. take that right back to the dealer.
Old Aug 13, 2006 | 06:23 PM
larry91403
So I guess what y'all are saying is to take it right to the dealer then? :P
OK
Thanks!
Old Aug 13, 2006 | 08:11 PM
ORIGINAL: larry91403
OK
Thanks!
the reason being, that car is still under warranty and if you mess around with anything it might void the warranty ........
dealer should do it free of charge
Old Aug 15, 2006 | 08:48 PM
fperezal's Avatar
DAAAAH!!!
