Flashing D4 and P1753
Old Dec 18, 2008 | 02:08 PM
karmajay's Avatar
Default Flashing D4 and P1753
Thanks ahead of time for anyone that can help!
I've had the "Maint Reqd" light on for a bit and figured it was due to a exhaust cat issue I had repaced and just needed to be reset. Today, I went over a small speed bump at a very low speed and when I hit the throttle nothing happened. The "D4" was flashing. I shifted into 1st and I could move fine. It seemed that I could manually shift fine but the car would not auto shift. I got home to do some research and decided to head to Autozone. I got in the car and travelled about a mile, the "D4" was not flashing and the car auto shifted fine. At Autozone,they pulled the "P1753" code out and it did not clear. When I started the car to drive away, the "D4" light was back on and I had to manually shift.
I don't think this is a physical tranny problem or I would not be able to manually shift or it would be constant. I've read it could be a speed sensor OR AT control unit. Is there anyway to pinpoint exactly what the issue is so I'm not buying 3 diff $100 parts? Thanks for your time!
Old Dec 18, 2008 | 02:18 PM
finch13's Avatar
Default RE: Flashing D4 and P1753
Main't Req'd is only a reminder to change the oil.
[align=left]P1753: Automatic Transaxle Concerns
[/align]
Old Dec 18, 2008 | 02:46 PM
karmajay's Avatar
Any ideas on how I can pinpoint the issue?
Old Dec 18, 2008 | 02:50 PM
finch13's Avatar
It could be solenoid A, solenoid B or the TCU... sorry I'm so vague, it's just I don't know specifically what would cause that.
Old Dec 18, 2008 | 06:54 PM
Any chance you heard or got the code incorrectly? P1753 primarily relates to Lockup solenoids, which should not affect shifting.
However, P0753 has symptom "fails to shift stuck in 4th gear". It is caused by an electrical fault in the shift control solenoid, wiring, or connector. Since this occurred after a speed bump, I would check the connector and wiring first.
Since someone else pulled the code, it may be worth rechecking.
Old Dec 18, 2008 | 07:22 PM
karmajay's Avatar
This would really jive with the flashing D4 as well I guess. Can you direct me to something that can show me where that connector is? Thanks!
Old Dec 19, 2008 | 10:31 AM
On 97 Accord the shift control solenoid is on outside of transmission, near radiator, slightly forward of the LockUp solenoids.
You might also try the online manuals at Autozone. They sometimes have necessary details.
Old Dec 19, 2008 | 10:39 AM
Tippman7641's Avatar
tbh, isnt that the "it means ur f***ed code" for those tranies?
Old Dec 19, 2008 | 12:39 PM
TexasHonda, his code is p1753.
In my shop manual P1753 is a problem with the lockup solenoid A or the wiring to it.
Old Dec 19, 2008 | 01:39 PM
ORIGINAL: PAhonda
I realize what code was posted, however I have seen errors in codes when transferred from one person to another, and P0753 is very similar and fits his symptoms more accurately, hence the question to clarify.
regards
