flickering headlights
Old Mar 28, 2016 | 11:02 AM
foghornleghorn's Avatar
Default flickering headlights
any help would be awesome. My headlights flicker all the time. It does not matter what is going on.
I want to replace the headlight with projector types so I can get HIDs. But I need to fix this flickering problem first.
Any ideas?
Old Mar 28, 2016 | 06:59 PM
What year and model vehicle are you working on?
Old Mar 28, 2016 | 07:06 PM
Dr. Drivability's Avatar
probably a bad ELD...
Old Mar 28, 2016 | 07:30 PM
its a 03 accord coupe v6 .. I replaced the ground going to the battery. I am going to replace the ground off the tranny and then the ground off the engine mount.
I had the alternator tested and it tested good
Old Mar 28, 2016 | 07:35 PM
Are both headlights having the same problem? Do you have a volt meter or test light?
Old Mar 28, 2016 | 07:57 PM
I just got a volt meter. I will test that as soon as i can.
I did notice it is all the lights on the exterior of car that flicker. I replaced my license plate lights with LED's and they now flicker
Old Mar 28, 2016 | 08:40 PM
Was any work done on the car right before they started flickering?
Old Mar 28, 2016 | 09:45 PM
no there was not. I let the car run for 30 minutes with the volt meter hooked up to the battery the whole time. When I first started it the lights flickered and the volts were 15.1-15.3. The volt eventually went down to 14.7 and the flickering stopped. The fan kicked on a few times and the volts dropped to 13.5 and the lights flickered, as soon as the volts went back up to 14.7 the lights were fine.
Old Mar 29, 2016 | 09:15 AM
If the issue happened right after you put LED license bulbs in, try swapping out for the originals and see if the problem goes away.
Old Mar 29, 2016 | 09:39 AM
this issue has been going on for a while. way before I installed LED plate lights. I am going to try the ELD bypass. I am going to get a 820 ohm resistor and bypass the ELD and see what happens. Otherwise I think I have a bad alternator
