front suspension clunking
Old Sep 27, 2011 | 03:31 PM
hispanicpanic's Avatar
that video called it a strut rod bushing. The acura's suspension in that vid looks exactly like the accords suspension.
If those bushings were bad, does that mean i'd have to replace the entire front cross member shown in the vid?
Old Sep 27, 2011 | 04:11 PM
What year, trim, transmission... accord are you driving?
Old Sep 27, 2011 | 04:17 PM
1998 ex, 5spd. f23a1
Old Sep 27, 2011 | 04:46 PM
What part number is bad in the diagram below?
Old Sep 27, 2011 | 05:02 PM
well i'm not sure if it is the proper source for the clunking, but i think its coming from part 6. and the bushings forward from it. 10 &11
Old Sep 27, 2011 | 05:12 PM
You might want to tighten bolt #27 to see if that helps the noise go away.
Old Sep 27, 2011 | 06:03 PM
  #17
Tek310's Avatar
Just replace the strut rod bushings. You do not need to replace the cross member. Very easy. Unbolt the front bolts first where it goes into the front beam of the sub frame. Then unbolt it from the lower control arm. Replace bushings, reinstallation is reverse order.
Old Sep 27, 2011 | 07:42 PM
  #18
As Tek said, if there is wear there, replace the radius rod bushings (pretty sure that is what Honda calls them). Please note that these can impact alignment (caster), some will say no, others will agree...after replacement (if bad) have the align checked just t be sure.
Old Sep 27, 2011 | 08:03 PM
  #19
Tek310's Avatar
Actually this is how caster is adjusted. Shims are added on the inside part of the rod to adjust the caster 1/4" per shim.
New bushings will effect your caster. Pushing your control arms back giving you more negative caster
Old Sep 28, 2011 | 12:27 PM
  #20
renzki's Avatar
The clunking sound is happening to me too since my #27 flew off (posted on another thread). If #14 is not seated on the subframe, the sound comes from the front threads of #6 rubbing through the subframe or #14 end sliding off the subframe
Thanks!
