-   -   Fuel Gauge Issue (https://www.hondaaccordforum.com/forum/general-tech-help-7/fuel-gauge-issue-49752/)
flossabe Aug 23, 2012 12:21 PM
Fuel Gauge Issue
So my fuel gauge or low fuel light do not show how much gas I have, or turn on when fuel is low.
But:...
1) I have tested the fuel sending unit and it tests to the standards of resistance listed in the shop manual, and have confirmed and tried with a second fuel sending uint...
2) I have confirmed 7.22 v on the white/yellow lead as indicated in the manual
3) I have confirmed the ground is good
4) bridging the ground and green (fuel light) leads turns on the fuel light
5) bridging the ground and the white/yellow starts to bring up the fuel guage
However when I have the fuel sending unit plugged in I cant get any readings on the fuel gauge nor the fuel light.
I am going to check the connections again but I wanted to post here to see if there is issue that I may not know about or that wouldn't be covered in the shop manual?
PAhonda Aug 23, 2012 07:11 PM
Are you sure about the 7.22V? I am almost positive you should have 12V.
