Sponsored by:
Sponsored by:
2005 accord timing chain problem
Old 10-05-2012, 08:36 AM
Accord 2.2's Avatar
Default 2005 accord timing chain problem
timing chain needs replacing.. mechanic said injectors have to come out but there seized and the will probably break.... is this job gona cost a fortune? HELP
Old 10-05-2012, 09:26 AM
shipo's Avatar
Why does the timing chain need replacing? Generally the timing chain will outlast the car.
Old 10-05-2012, 09:51 AM
Dr. Drivability's Avatar
X2, why does the chain need replace? what happened? is injector removal a seperate issue, cuz they don'ts gotz to come out to do the chain...
Old 10-05-2012, 04:34 PM
jujuCO's Avatar
the injectors don't have to come out....they are part of the intake manifold....
take the valve cover off....take the side cover off.....load your tensioner...take tensioner off...swap your chain....
easy.
deerdawg
04-27-2013 08:35 AM
bougie_44
11-27-2011 08:22 AM
ss485
02-23-2011 08:18 PM
harrishonda
10-03-2010 03:59 PM
Quick Reply: 2005 accord timing chain problem
